As Viper stated, it could be the timing. My first suspect would be weak or broken springs on the centrifugal advance mechanism in the distributor or even corroded and stuck centrifugal weights. The springs control the rate at which the weights fly outwards to advance the timing. If they are weak or broken, the weights will put the timing in full advance during cranking.
On our race car engines we lock the timing out and that puts the timing in full advance at all times. For starting I program the ignition box to retard the timing 10 degrees to make starting easier and avoid kickbacks. Drag race engines essential run at wide open throttle all the time, so vacuum or centrifugal advance is not needed.
Hard spot while cranking
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
Re: Hard spot while cranking
Update to the update...after testing, it was indeed the broken spring.
It starts as it should and sounds great. Boat is up and running and ready for Desolation Sound....
May 5th I'll be moving it from Dagmars in Everett (Dry dock) to Pt of Edmonds, in a covered slip.
- mjk1040
- Been thanked: 248 times
Well I didn't see that as the hard start problem coming! A spring!!
Mike
