Slow drip down where stuffing box is. Nut is stuck
- RickieT
- Vessel Info: Carver 350 Mariner 1997
- Has thanked: 18 times
- Been thanked: 3 times
- Contact:
Trying to tighten the big nut to slow down a drip and it seems to be be stuck from lack of use? Is there something to spray on there to get this nut to turn???? It's tight down there any ideas on which tools are needed???
Many thanks,
Rick
- mjk1040
- Been thanked: 242 times
Re: Slow drip down where stuffing box is. Nut is stuck
- Has thanked: 455 times
- Been thanked: 1671 times
- Has thanked: 53 times
- Been thanked: 426 times
36 " pipe wrench work wonders
- Has thanked: 324 times
- Been thanked: 595 times
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
All above about the two nuts is true.
Get two vise-grip with the rounded jaws.
Here is an example of what it looks like...the round jaw type, not the other. ..
http://www.emedco.com/irwin-vise-gripr- ... =vise+grip
If they leak after you tightened to a 4 drip per minute flow, you may have: old packing, bent shaft or corrosion on the shaft.
Been there, done that and didn't want a T-Shirt...it sucks bad. Sorry to hear of your pain...
- RickieT
- Contact:
- mjk1040
- Been thanked: 1043 times
DON'T try to use these... they are not strong enough to loosen or retighten the nuts
- mjk1040
