355 Carver shift problems
Topic author - Scurvy Dog
- Vessel Info: 2004 466 Carver
- Has thanked: 53 times
- Been thanked: 426 times
Re: 355 Carver shift problems
If the clutches are slipping, it's toast or is going to be.
Determine what transmissions are installed on the boat.
Do an internet search for that transmission manual. You will find one free. You'll find places that want to charge you for it, but they are free. You just have to look. Download and read how to make the shift cable adjustment and/or assess if the cable is bad, components worn, etc.
Again, there should be no delay.
- Ramsport47
- Has thanked: 72 times
- Been thanked: 57 times
T-Merc 350 Mag MPI (300hp)
- Vessel Info: 1995 Carver 355 Aft Cabin
- Been thanked: 2 times
I was sure glad because I was already thinking shaft seals, front pump seal, etc.......
If your trans is a ZF model I have the repair/parts manual if you need it.
Iuka, Ms
1987 Carver Santego 2767
1984 Bayliner Capri Cuddy
2005 Bass tracker 1850
- Location: Eisenhower yacht Club, Lake Texoma, Sherman TX
- Been thanked: 4 times
Lake Texoma, Denison TX
Port: EYC Marina
2001 406 twin 380HP 454 MPI
