LAUNCH
Has thanked: 584 times
Been thanked: 1227 times
Re: LAUNCH
Postby bud37 » April 21st, 2018, 6:49 am
denpooch wrote:Source of the post Bud please be sure you post your launch. We will all celebrate with you.
God Bless You my Canadian friend!
Will do sir and thank you for that ..... :beergood:
FWIW.....The above is just my opinion..... :popcorn:
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 65 times
Re: LAUNCH
Postby feeez » April 21st, 2018, 10:08 am
Salivate.... Salivate
I am getting antsy with each passing day.... 13 C to day and warmer through the week.... we are getting there.
Cheers
Fraser
Former 2001 350 Mariner owner
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: LAUNCH
Postby Lyndon670 » April 21st, 2018, 6:23 pm
I am splashing on May 7th. Hopefully by next weekend I can get some bottom paint on. The surface temperature of the hull is still to cold to apply paint - the thermal mass of the boat is keeping it cold to the touch.
That....and I'm afraid to pull the shrink wrap off i ncase we get another dump lol...
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
feeez
Re: LAUNCH
Postby feeez » April 21st, 2018, 8:54 pm
The ground around ours is going to be like a swamp after all this melts. I also need some decent temp to compound the hull before launch. I am still hoping for a pre victoria day launch..... fingers and toes crossed.
Cheers
Fraser
Lyndon670
Volvo TAMD74EDC
Re: LAUNCH
Postby Lyndon670 » April 21st, 2018, 11:08 pm
PRE VICTORIA DAY???
I have a weekend planned with another couple on board for that weekend!!
Say it isnt so Fraser!!
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
throwback2
Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys
Has thanked: 8 times
Been thanked: 22 times
Re: LAUNCH
Postby throwback2 » April 22nd, 2018, 12:22 pm
Splashed my 28 Carver this morning.After checking the bilge,I hit the starter on the starboard engine and it fired right up but didn't sound as quiet as normal. I went down and checked it out. Sure enough,it wasn't pumping water.Pulled the hose off and was still full of pink antifreeze.I figured I cooked an impeller but it was fine.(Only a year old too) I tried to blow back through the hose and it was hard and then it let go and blew bubbles out the bottom of the boat. i went to put the hose back on and muddy water came out .Hooked it back up and all good.Now for the port engine; cranking....,no fuel.Pulled the flame arrrester off and acceleration pump was stuck down.I poured some gas in the bowl vent and it popped up so quick 3 pumps of the throttle and she lit right off. Heres to a great boating season !
Has thanked: 55 times
Been thanked: 438 times
Re: LAUNCH
Postby waybomb » April 22nd, 2018, 5:19 pm
They let me bring mine over to my slip.
They are still looking for the drowning victim though.
Been thanked: 243 times
Re: LAUNCH
Postby mjk1040 » April 22nd, 2018, 8:15 pm
Well it was a wonderful warm day here in NY, almost 60 degrees, so I thought might as well get her uncovered and let the rain coming in a couple days wash her down! To my surprise my bow had been hit and bent our bow pulpit railing!!! :confused: I'm thinking travel lift? I'm thinking this is going to be an interesting conversation with the marina owners and help?
feeez
Re: LAUNCH
Postby feeez » April 22nd, 2018, 8:33 pm
Lyndon670 wrote:Source of the post
PRE VICTORIA DAY???
Nothing but positive thoughts for you Lyndon..... it's going to happen!!!
Cheers
Fraser
Has thanked: 457 times
Been thanked: 1687 times
Re: LAUNCH
Postby Viper » April 23rd, 2018, 7:31 am
mjk1040 wrote:Source of the post.....I'm thinking travel lift?....
Unless they pulled out at a very tight angle, that would be pretty difficult to do with a travel lift unless they hit it passing by later. If it was hit with the lift, that's a close call, she could have been knocked over. Look for scratches on the rail. Another possibility is snow load. Did they install a ridge pole right to the end of the bow rail and was it supported by a leg or was it sitting on the bow rail?
Users browsing this forum: Mablett and 33 guests
