390Express wrote:Qr Bbpost....to be clear, that is 1-2 cups worth of milkshake water/transmission fluid mix.....
If it's a milkshake, it's an indication that it was RUN with water in it, not from condensation since last used.
Viper wrote:Qr Bbpost390Express wrote:Qr Bbpost....to be clear, that is 1-2 cups worth of milkshake water/transmission fluid mix.....
(had to be careful there...) but I couldn't get anything to draw out of the return line I'm guessing that pickup doesn't go to the bottom of the tank. I could hear air going in and out of the line, but no gas would come out. I don't know what could be causing the issue with not being able to get fuel out of the supply line, other than some sort of blockage, but I don't see how that line could be totally blocked?...
tomschauer wrote:Qr Bbpost Hopefully you don't have a leak, but 1 1/2 cups of water is to much for condensation. Also, if it was condensation both gear boxes would have the same, or very nearly the same amount of water in them.
Keep a very close eye on it.
