V Drive Transmission Drip
Outandaboat
Vessel Info: 2000 350 Mariner
Post by Outandaboat »
I have noticed a small drip that started under my transmission. It's a 2000 350 Mariner and no idea what the V drives are and haven't worked on these things before. Anyone know if these are hard to work on? Could it be a gasket? Any help is appreciated.
Been thanked: 1114 times
Re: V Drive Transmission Drip
Probably not as likely a gasket as it would be a seal. Wipe it all down and then see if you can tell which end the leak is coming from. Tape some strips of paper towel or those oil absorbent pads under the area to help see where it drips first, but it might just travel to the lowest point before it drips.
You did not say what engines you have there.... if they are black ones and if it turns out the shaft seal is leaking , I am given to understand that there was a shaft seal upgrade way back around early 2000's as they had some issues with leakage....my boat had been upgraded under warranty on at least one side......if its just a drip put a tray and pad down like has been mentioned and see what amt you get after a while , just watch your levels. Good luck man as I believe you have to remove engine trans combo to efficiently repair unless you have E.T. working for you.
To add , I have the small block 6.2 so this may not even apply if you have big blocks or diesel.
rybad
Vessel Info: 1987 Carver Mariner 3297 w/ Crusader 270's
Has thanked: 6 times
Post by rybad »
Im not sure if you have resolved this by now, but I just joined this forum and saw this point, and figured I would share my transmission/vdrive experience.
First off, there should be a tag on the VDrive part of the transmission that has the gear ratio and transmission type (I have an 87 Mariner with Borg Warner Velvet Drives).
I had one trans go out on me. It would heat up, then not shift. I had it replaced. Cost me about $1100 for the shop to do the work, but I found a great deal on a complete rebuilt transmision & VDrive unit (all assembled). I got both for $3500 which, if you have been looking, is an extremely good price.
Anyway, if you need to replace, check out ebasicpower.com That is the place I got the trans and vdrive from.
Now, I will also tell you, if you end up buying from the, be sure to have them double check and bench test before shpping. I had them ship me one, paid the $3500, had it shipped to my marine mechanic. Marine mechanic installed the trans, and after first trip out, the seal was leaking. I called ebasicpower.com, and they sent me a replacement seal, but the whole thing had to be pulled all over again.. so it cost me another $1100 to replace a $29 seal!! That sucked.
Good Luck
