Mufflers/exhausts
- quickdecision
- Vessel Info: Carver 3807, 1987
- Been thanked: 23 times
Re: Mufflers/exhausts
Here's what I have found so far, These are 4" 1n/out connections. P/N 15800088 this is the vertical. The inline 1500098 12" dia X 22' long. I have started to locate both new and used are available.
I assume you mean the 1500088. Let me know which one you manage to fit in there. They are both lift mufflers and while the base mounted unit is a no-brainer in terms of mounting on a horizontal surface, I'm pretty sure the the in-line unit needs to be level which may be a challenge the way the exhaust is configured. You may want to consult with Centek first. If it can be mounted on an angle, it would fit in mine.
- rybad
- Vessel Info: 1987 Carver Mariner 3297 w/ Crusader 270's
- Has thanked: 6 times
I'm very curious on this topic. I have a 1987 Mariner 3297. She is very loud in the marina.. underway its not bad, but I hate to be the first one to fire up in the morning cuase she is soooo loud. I was contimplating putting a down-pipe so it at least goes under the water, but I dont know enough about back pressure and other things that need to be considered and I dont want to screw something up. I do have these "mufflers" inside the bildge. That are black rubber things that connect to the 4" house to the through hull fitting. But that are so small I cant imagine them helping much (but maybe they do)
Anyway, if someone has found a way to quiet these down, I would love to hear about it. Although, I dont want to sacrafice too much economy just to be quieter, but if its minimal, I'm good.
I have Crusader 270's.
