Vacu Flush Woes
- Has thanked: 269 times
- Been thanked: 1153 times
Vacu Flush Woes
Additional info: Worked perfectly fine last fall before winter layup and never an issue. No lines were disconnected or valves closed for winter layup. My procedure is to make sure the holding tank is as empty as possible and since the toilet draws water from the potable water system I simply flush the toilets while connected up to the "pink stuff" until I get a good stream of pink. Flush once and repeat a second time.
- mjk1040
- Been thanked: 242 times
Re: Vacu Flush Woes
Re: Vacu Flush Woes
98% sure this is what I have. https://www.dometic.com/en-ca/ca/produc ... g4-_-25287
Found this which basically shows me what could need replacing. After watching this I now think it could be some worn duck bill valves that maybe did not like the pink stuff.
Exploded parts view diagram. https://seacoastservices.com/jw-series- ... vg4-parts/
- Has thanked: 456 times
- Been thanked: 1671 times
Re: Vacu Flush Woes
Re: Vacu Flush Woes
Did order 2 sets of duckbill valves https://www.marinesan.com/2-Duckbill-VG ... 311581.htm as they probably need attention regardless if they are not the problem. Pretty sure these are the originals at 10 years old.
- Has thanked: 580 times
- Been thanked: 1210 times
Re: Vacu Flush Woes
Midnightsun wrote:Source of the post Pretty sure these are the originals at 10 years old.
I think you may have found the problem....good luck with it.
Re: Vacu Flush Woes
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
Re: Vacu Flush Woes
What started this problem was a broken bellows. It just ran and ran without building a vacuum. I was however impressed that the duckbills were still doing their job after seeing their condition after removal.
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat.... )
Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
Re: Vacu Flush Woes
Re: Vacu Flush Woes
