Hi, I have a Carver 32 1995, and I want to change my window weather strip, most of them have dried out and some pieces are missing.
I have found the replacement but how can we take out the old ones ? I have tried with a knife, screen driver with no succes. They are in some kind of groove within the window, I have attached some pictures.
Window weather strip
- Rocket09
- Vessel Info: Carver Aft 325 - 1995
- Been thanked: 2 times
- mjk1040
- Been thanked: 248 times
Re: Window weather strip
You have to pull it out. Its in a track and I do not think you will be able to reinstall new in the track, its a PITA! I found and purchased my new stuff with 3m tape on it and stuck it onto the track. The only way I could see to re-track it was to take the window frame track apart and since its welded it didn't look to be an option. Good luck with ur project!
Mike
- sandro.klersy
- Vessel Info: Carver 2897 Mariner 1988
- Has thanked: 4 times
- Been thanked: 6 times
Hi Rocket09!
Can you tell me where you have found the wheater strip or brand of it?
- mjk1040
Goggle pile weather striping.
Mike
- Rocket09
sandro.klersy wrote:Qr Bbpost Hi Rocket09!
As soon I get on the boat this week, I will let you know
- mjk1040
An after thought. If you can find the replacement weather strip with the plastic backer that goes into the window frame track, I guess you could use a dremil tool to remove a portion of the frame track lip to give you a starting point to insert the new weather strip and feed a pre cut section into the frame.
Mike
- Djphink
- Vessel Info: 1994 Carver Mariner 330
You can get the weather stripping from Taylor made systems. I just replaced all strips on 1994 Mariner 330. 264 feet of it was $376. Not cheap, but windows are like new
- Djphink
- Been thanked: 1114 times
Perhaps because that's the manufacturer? http://www.schlegel.com/eu/en/catalogue_item/SchlegelPolyBondPBWovenBrushPileSeals/
They seem to have several different styles. Do you guys have pictures of what you installed?
