SanJuanDreamer wrote:Source of the post....#3 at 130lbs, still within spec, but -2lbs less and it would be problem......
I wouldn't worry much about 130lbs or 10lbs less!
SanJuanDreamer wrote:Source of the post.... After he left......The gauges dropped to ~5lbs......
Again, this needs to be confirmed by a test instrument. You can't assume the sender, wiring and gauge are working properly throughout the entire operational range and conditions. He needs to test it while on a sea trial to mimic the same operational conditions before you condemn the engine.
SanJuanDreamer wrote:Source of the post...... The oil was changed 10hrs ago, it smells gassey, which indicates gas is getting by cylinders or the TBI is providing too much fuel.
Going to use it gently over the summer and schedule for a repower.
You really should find out what's going on here as this may be causing the low oil pressure so you need to eliminate that as a possible cause. When fuel is getting into your sump, there is no such thing as "using it gently over the summer" It's not good to have or run with explosive vapours in your sump.
