Mattress Replacement DIY
- Has thanked: 268 times
- Been thanked: 1153 times
Required a Queen size to fit the master. The guest required a king and even this was not big enough due to the weird bow shape/fitted design. Luckily the waste after the cut was big enough to glue the missing piece into place creating an identically sized copy of the original. Used a spray adhesive made for foam which worked perfectly. The bow mattress (guest) also had angles on both side to fit the hull shape so this one was trickier than the master.
Laid the old mattress on top of the new and traced out the pattern with a marker. Checked out youtube and found the recommended way of cutting the foam was with an electric carving knife which also worked well. The Morgedal mattress we chose has a zipped on cover which was removed, modified/sewn to fit the new cut mattress shape. https://www.ikea.com/ca/en/catalog/products/40272211/
Picture of the Guest mattress which was the complicated one, Master is the same but a different shape. Very pleased with the results.
- pepmyster
8.1 Volvo Penta
- Has thanked: 474 times
- Been thanked: 201 times
Re: Mattress Replacement DIY
- Bacchus
- Vessel Info: 1993 Carver 300 Sedan
Now - your next assignment is to to make a set of custom sheets to fit the weird shapes.
I have done several sets and they are not all that difficult.
I buy individual flat sheets at Target or W World
Trace shape and cut out the top leaving an inch or so for seaming
Measure mattress thickness and add several inches to fit under the mattress and to sew a hem in the bottom edge - I sometimes buy and extra sheet to have enough matching mat'l for the side pieces.
Sew several side pieces together to have enough to go around the outside edge of the mattress - better to have too much than not enough.
Sew a hem in one edge to put in elastic or a draw string. Insert a string as you sew the hem of after w/ a small snake pushed through the hem to pull the string back through.
Sew the side to the top starting at a position that will be easily accessible when making the bed. - continue to sew until you approach the starting point - cut and finish the cut edge and complete sewing the side piece on.
The fitted sheet can be placed on the mattress and the string used to draw it tight - I have used a slide lock similar to those used on jacket bottoms to hold the draw string. If desired you can use the string to pull an elastic through the hem and tie the end together to provide a fitted sheet w/ an stretchy side panel fit.
Hope it helps
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 467 times
- Bentone23
- Vessel Info: 1996 Carver 355 Aft Cabin
454 xli TBI Crusaders - Location: San Francisco Bay
- Has thanked: 57 times
- Been thanked: 5 times
- Contact:
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
- Bentone23
- Contact:
1996 355 Aft Cabin
Central California
- jasontn
- Vessel Info: 1986 Mariner 3697
Were you happy with the mattress and if so would you be willing to share the information of the company that made it?
Midnightsun - Great job, that looks great.
- chpsk8
- Has thanked: 27 times
- Been thanked: 75 times
Users browsing this forum: Google [Bot] and 17 guests
