1988 MONTEGO 2757 My first :)
- tammymae17
- Vessel Info: 1988 2757 Montego
- Has thanked: 4 times
- Been thanked: 3 times
Re: 1988 MONTEGO 2757 My first :)
Some of the interior work I've done...
Sanded down and refinished all the wood stairs and trim
[attachment=0]20180412_190708.jpg[/attachment
- tammymae17
Some of the interior work I've done. Sanded down and re varnished all the woodwork and trim.
Yes, you only have 120 volts when on shore power. You would need to add an inverter to run off the batteries. Also, the 2757 didn't come standard with a battery charger, if you don't have one you may want to add it.
Looks good!
What is that piece of PVC pipe and valve coming up through the galley counter top?
- tammymae17
I sanded down and stained / re- varnished the stairs and all the wood trim.
