Kohler generator for dummies, questions
- smcguckin27
- Vessel Info: 2004 Carver 360 Sport Sedan.
- Has thanked: 8 times
- Been thanked: 9 times
Re: Kohler generator for dummies, questions
- Has thanked: 579 times
- Been thanked: 1210 times
- buster53
- Been thanked: 261 times
buster53 wrote:Ok, I have a Kohler 7.3E-CB. Yesterday, I ran the unit for about 30 minutes, mostly running one AC unit and both AC units for 5-10 minutes.
Genset shut down. Restarted and ran for a minute or two before shutting down again. This happened several times and would only run a minute or so. After 5-6 restarts, it would only run for a few seconds before shutting down. Just bought this boat in March and haven't had any problems until today.
I checked to make sure my oil level was good. What's next...replace fuel filter maybe? Any other suggestions?
Ok, had a tech guy look at my genset and he tells me the fuel pump is shot. He suggested I order the pump and when it comes in, he will install it.
Where's a good place to order Kohler parts?
- Vessel Info: 1977 Carver Mariner 2896
- Has thanked: 37 times
- Been thanked: 1043 times
Ctmangrum wrote:Source of the post Just a question for an old post. Does the generator cool using the starboard engine sea strainer?
Not typically. They almost always have their own through-hull and sea strainer.
Like KM says......Thats the thing with old boats, you can never be sure what someone has done before you......just follow the water hose back from the pump on the gen. to its source.
If that gen was added later ( DIY) they may well have done some odd things so have a real good look. It should have its own dedicated cooling water supply unless there is a sea chest, which I doubt on your boat.
Users browsing this forum: No registered users and 82 guests
