faucets
A Lee
Vessel Info: 2005 56' Voyger
Been thanked: 3 times
Re: faucets
Postby A Lee » July 6th, 2018, 2:37 pm
I replaced a shower faucet single handle from Lowe's. The pressure is much less than the other shower and sinks. It is the same if on shore or boat water. I checked for a water saver and found none. Any suggestions would be appreciated.
Been thanked: 615 times
Re: faucets
Postby g36 » July 7th, 2018, 9:09 am
Mine was actually better after replacing. Shouldnt have any flow issues. You checked in the shower head and hose to it for water saver? What faucet model?there may be flow limiter built in to the valve. Looks like some you can adjust .Some look to be non adjustable. I looked at mine again forgot I had to use the tub outlet and capped off the shower output due to the way I had to mount it.
Users browsing this forum: No registered users and 68 guests
