Transmission Fluid Pump
- crquisto
- Vessel Info: 2000 Carver 406 Aft Cabin, twin 7.4 gas Mercruisers - Flyboy II
- Has thanked: 2 times
Today I decided to change tranny fluid to see if that might help. The old fluid (2 years and 70 hours run time) looked and smelled normal - not burnt. I added 1.8 quarts to the port engine and checked the level as prescribed (run at 1500 rpm for 2 minutes, shut down and check it quickly). It showed over-filled. On the starboard side, I added 1.8 quarts, ran it and checked and the quantity was low - needed another .2 quarts for a total of 2.0.
In light of the warning, no engine anomalies, and the fluid showing over-full after running, the only conclusion I can arrive at is that the pump is not working to push fluid into the cooler and other parts of the tranny.
1. Is that a logical conclusion?
2. If so, can a pump be replaced in that model Velvet Drive?
3. I didn’t see any hose crimps, but could there be blockages in the fluid system that I could clear to correct the problem?
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Transmission Fluid Pump
- Been thanked: 1043 times
Does it shift properly? If it does, then it certainly is pumping. It may not be developing enough pressure though and allowing it to slip and increase temperature. As buc37 says, check what the alarm is actually telling you.
- Has thanked: 324 times
- Been thanked: 595 times
- crquisto
Do you have a dedicated oil cooler for the tranny or is it shared with your engine oil? Do you have an IR temp gun? You could easily spot check temperatures on hoses and the heat exchangers if you did.
crquisto wrote:Source of the post The alarm warns of low engine oil pressure, high engine temp and high transmission temp. I have gauges for the first two, so I’ve gotta think it’s the tranny. It shifts properly and seems to pull alright but I don’t know how to check for slippage. Thanks for the suggestion on the screen. I guess that would probably be where one of the hydraulic hoses connects to the tranny?
Did the oil from that tranny come out clean with no dark coloured bits in it...it is the red fluid correct ?
- crquisto
Bud37, it is the red Dextron III and it was slightly discolored but no chunks and it smelled ok
- Has thanked: 455 times
- Been thanked: 1671 times
- crquisto
Users browsing this forum: No registered users and 48 guests
