The launch went well. Both engines fired right up after their almost 8 month nap. Since I had to work that Friday I only took a short shakedown cruise. The following day I did make a short trip to Bob Lo Island Marina for a boat club rendezvous. I stayed for the day.
The launch was not totally trouble free. When I got back to the dock and hooked up my shorepower I found that my A/C was not working. I am getting power to the unit as the blower fan does come on. But, I am not getting any power to the thermostat for some reason so I cannot turn the unit on. So, for now no A/C. I have checked what I can check so I guess it is time to call in a pro to see if it is fixable. I am not sure how old the unit is but it worked fine the last 3 seasons. In fact it was working last year the day I pulled the boat out of the water although it was in heat mode that day, November 2nd.
I am prepared to install a new unit if needed but am hoping it is some sort of simple fix. It is a Cruise Aire unit which I believe is now Dometic. I called customer service and without seeing the unit they thought it could be the electronic card in the unit. I don't want to break anything so I am not getting to involved in taking things apart. I tried to pop the thermostat cover but it did not seem to want to move. Of course I am probably doing it wrong.
Anyway the boat is in the water and I have had it out a couple times now last time for the Trenton Michigan 4th of July Fireworks.
Finally, my boating season has begun.
