Aft deck plastic panels
Used boat parts, used Carver boat parts, trailers, dinghies, outboards, props...everything but the boats they were attached to. ALL ADS ARE FREE - USERS MUST HAVE AT LEAST 10 POSTS TO PLACE AN AD
Forum rules
All classified ads for boat parts are free. Please be as specific as possible in describing your item. You can upload pictures too!
CarverYachtOwners.com and the owners of this forum take no responsibility for the authenticity of ads or legitimacy of items being sold. Buyers, please buy responsibly.
To place an ad start a new Topic. We reserve the right to delete ads from users with fewer than 10 posts.
Been thanked: 248 times
Re: Aft deck plastic panels
Post by mjk1040 »
greg, search this site, the stand offs and rivets are on here somewhere.
Post by g36 »
I know i posted this earlier but if you've lost panels or see where others have I would use the standoffs and wouldn't use rivets again just seems like it's a matter of time. On my 405 i replaced all mine with screws with white trim covers I just decided before I have this problem others have is to be proactive and not repeat this mistake
Wayne162
"Change In Latitude"
Has thanked: 16 times
Been thanked: 32 times
Post by Wayne162 »
I ran into the same issue and had a lengthy post about the acrylic panels that were no longer available from Carver. I lost mine to hurricane Matthew. Problem with the Carver OEM panels were that on my 405 they measured 9' and aftermarket acrylic panels are made from 4x8 sheets. I found a local specialty metals fabricator and had him make new panels from marine grade aluminum and powder coated the new panel. I had one remaining corner left that they made a mirror image of from the Starboard side extruded corner. I decided to jazz it up a bit with a custom decal on the new panels. The manufactured aluminum was half the price of new acrylic.
Post by g36 »
Maybe you need to have that guy hold onto a pattern for these and I bet it might get more 405 owners do the same. BTw maybe you could put up the company info.
racerrick
Vessel Info: 1986 3607 Aft Cabin. Berthed Palm Island Marina, Cape Haze, FL
Post by racerrick »
I had custom fiberglass panels made. Wasn't cheap but durable & very ship shape. Fortunately his shop is only a few blocks from where I had the boat berthed. They are two one piece panels, I have no idea how he did it or if he can do it without being on the boat. He has a great reputation around Destin & the Emerald Coast.
John Sullivan, 203 Early St Niceville, FL 32578 (850) 729-1418
Wayne162
Post by Wayne162 »
I posted Metal Specialties who did my work, but the information did not post. Here goes again.... I agree that the work needs to be hands on due to the complexities of the fabrication.
:usa:
Metal Specialties
1 Compass Road
Mt. Holly, NJ 08060
(609) 261-9277
Looks great RR
Ssmullugan
Vessel Info: 2000 Carver 326 aft cabin
Has thanked: 3 times
Post by Ssmullugan »
We had some damage to the boat because of a storm. Lost a panel and the “corner piece”. Found the panel, but corner piece is long gone. Started the search for replacement. Looks like that is a deadend. Seems fabrication is the answer?
Thanks for the forum!
Wayne162
Post by Wayne162 »
Ssmullugan,
I took my remaining corner to the fabricator and had them make me a mirror image of the one I had. I would suggest to attach a weatherproof lanyard through a drilled hole in the new and remaining corner and affix it so that it cannot be lost again.
:usa:
KEND
Vessel Info: 1991 Carver 33' wide body aft cabin model 3330 twin 330hp Volvo's
Been thanked: 2 times
Post by KEND »
I also have two cracked panels for my 1991 33 aft, My problem is I cannot get the corner piece off the plexiglas panels on either side, so without separating the plexiglas I cannot use the corners. They seem to be locked on, maybe glued, not sure , all I know is no matter what, I have even tried to separate them using a razor knife to scrap inside the edges. No matter what I try no luck, any suggestions ?
