Cabin Lights Carver 53 Voyager 1999
swaterbly
Vessel Info: Change "N" Course - Carver 530 Voyager Volvo TAMD122a-P
Post by swaterbly »
Need a source for salon lights in a Carver 53 voyager. Outside diameter is 2 1/2 inch and 1/2 inch recess. Fixture has three screws holding it in the head liner.
Re: Cabin Lights Carver 53 Voyager 1999
Welcome to the forum......do a search on the forum for salon led lights and you should get lots of info....sounds like you have the hera lights, there will be a name on the frame on them, If so you may find some still around.....good luck....... :beergood:
vohn
Vessel Info: 530 Voyager
Post by vohn »
Welcome,
If all your bezels are OK you can just buy small LED bulbs:
https://www.amazon.ca/gp/product/B0792XGCM5/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
If any of your bezels are broken you will need to replace the whole light - not just the bulb.
This is what you would need. Not cheap but bright and fit perfect. I did the whole boat.
https://www.amazon.ca/gp/product/B0105KS95C/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
Also note: if replacing the salon lights you will need to change out the dimmer module as OEM doesnt work for LEDs.
