'98 350 Mariner Pump Out
- grizer
- Vessel Info: 1998 Carver 350 Mariner
- mjk1040
- Been thanked: 243 times
Re: '98 350 Mariner Pump Out
- Has thanked: 583 times
- Been thanked: 1226 times
Edit.....to add, have a look at your holding tank to see if it is collapsed a bit....there should be tank saver valve in it that stops that if you have the vac flush toilet.
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
I have not issues with my 350 Mariner when we pump out. It empties fairly quickly. This brings into question, what your putting into the tank that might be clogging up the lines.
- grizer
- mjk1040
https://carveryachts.blob.core.windows. ... ver_98.pdf
- amanphoto
grizer wrote:Source of the post Interesting, where is the holding tank vent located on a 98 350?
On my 99 Carver 350, the holding tank vent is a silver vent similar to the fuel tank vent. It is located port side just behind the sink (about midship).
If you remove the dinning room table back seat cushion and unscrew the plastic panel adjacent to the sink you an see the vent line and check to see if it has a charcoal filter that may be clogged.
- mjk1040
- grizer
