Port Engine Continues To Run Even With Key Removed...
mbjezior
Vessel Info: Carver 370 Aft Cabin
Re: Port Engine Continues To Run Even With Key Removed...
Post by mbjezior »
May have figured it out....replaced the ignition relay and so far after three runs and shut downs could not duplicate problem of continuining to run...
mbjezior
Post by mbjezior »
That may have been the solution- replacing ignition relay ...after three normal runs with shutdowns could not duplicate the issue of having the motor contining to run...
Post by tomschauer »
do you have two stations? If so there is most likely a relay somewhere for the ignition circuit.
I don't believe an alternator diode would cause this issue.
