Spare Parts while on a LONG passage
Has thanked: 324 times
Been thanked: 595 times
Re: Spare Parts while on a LONG passage
Postby tomschauer » August 20th, 2018, 10:12 pm
What ever you take as spares will not fail. It will be the simplest, cheapest item, and you wont have it. :-P
So the AMEX Black card is the most important thing.
Kendaukcat
Has thanked: 14 times
Been thanked: 4 times
Postby Kendaukcat » August 24th, 2018, 7:27 am
waybomb wrote:Source of the post One thing that I have on PV that I don't on our Carver is a hand operated diaphragm pump, hard mounted to a bulk head.
I've been thinking of installing one on the Carver as well.
I did install a high water alarm on the Carver as well.
Interesting. Do you recall what you used for a high water alarm?
Has thanked: 53 times
Been thanked: 426 times
Postby waybomb » August 24th, 2018, 12:43 pm
The water alarm, I believe, is a Rule. Float and an alarm with a light, about the size of a small engine gage.
Has thanked: 268 times
Been thanked: 1153 times
Postby Midnightsun » August 24th, 2018, 1:00 pm
My Carver has one from the factory but my previous boat did not. Did not like the ones on the market because they look so old and found them quite big. Made my own with a float switch and this which is a combo buzzer/light. https://www.ebay.com/itm/One-AC-DC-12V- ... 2761539371
You can see it here on the starboard side. Pretty proud of the entire custom dash I made for that boat. Even went with push button start. :-D
Keith S
Vessel Info: 2005 38 Super Sport
Been thanked: 21 times
Postby Keith S » August 24th, 2018, 1:19 pm
I was asked where I store all the spares. Actually that was only a partial list, I actually carry much more. All the parts are in the cockpit bilge and the engine compartment in numbered plastic bins. I keep a note book with the inventory and note which bin each part is in. While it may sound crazy to some, my trips are usually a week or two in areas that don't have full service marinas. I started carrying a lot of "stuff" when on one trip I had a leaking oil pressure sender. I just needed a 1/8" pipe plug to seal it off. After 3 days in a row at 3 different marinas, no plug! I finally found a dead engine in the back of the yard that I got one off of. I learned to prepare as much as I possibly could for any failure. Now since I'm a marine tech by trade, I don't pay full retail and I can install the parts as needed. My wife laughs at me for all the "prepping", but she is happy when the A/C pump quits and I replace it with the spare and the cabin is cool again.
Users browsing this forum: No registered users and 101 guests
