Shore power 36 SS
- Whyknot
- Vessel Info: 2003 Carver Sport Sedan
Volvo Penta 375 HP GAS
Koehler generator
Bow Thrusters - Location: Rhode Island Wickord
Shore power 36 SS
My 2003 36 SS Gas is burning the shore power ends actually caught fire twice
Any suggestions on cause and how to fix. Ends were replaced twice
- Has thanked: 268 times
- Been thanked: 1153 times
Re: Shore power 36 SS
- Has thanked: 455 times
- Been thanked: 1671 times
You should also take voltage reading from the pedestal. Even with good connections, low supply voltage (common in marinas) will cause an increase in current resulting in heat. Eventually this heat will cause connection and cord failures not to mention sensitive electronics associated with most on-board systems such as fridges, air conditioners, chargers, etc.
- Has thanked: 324 times
- Been thanked: 595 times
- pepmyster
8.1 Volvo Penta
- Has thanked: 474 times
- Been thanked: 201 times
- buster53
- Been thanked: 261 times
Also, whenever you connect/disconnect your power cords, make sure there is no load going thru the cords. Kill your breakers either on the boat or pedestal before disconnecting your cords. This prevents any arching which over time, causes problems.
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat.... )
Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
Users browsing this forum: Google [Bot] and 114 guests
