Hot Manifolds
Has thanked: 324 times
Been thanked: 595 times
Re: Hot Manifolds
Postby tomschauer » August 19th, 2018, 10:12 pm
The riser gasket is also a good place to lose coolant into the raw water side of the system
390Express
Has thanked: 141 times
Been thanked: 15 times
Re: Hot Manifolds
Postby 390Express » August 22nd, 2018, 12:40 pm
tomschauer wrote:Source of the post The riser gasket is also a good place to lose coolant into the raw water side of the system
Thanks for the tip, I forgot that the coolant side and the fresh water side mix at the riser, so the fresh water has a place to exit.
I like this color coded diagram by CP Performance:
http://www.cpperformance.com/t-marine-c ... stems.aspx
Been thanked: 242 times
Re: Hot Manifolds
Postby mjk1040 » August 22nd, 2018, 9:24 pm
Closed cooling has to have the air bleed off to get the entire closed system full of 50/50 mixed antifreeze. One should fill as the engine is running and as the thermostat opens you should see coolant movement in the radiator cap. There may also be a bleeder valve in line to bleed the air out of the system!
Has thanked: 579 times
Been thanked: 1210 times
Re: Hot Manifolds
Postby bud37 » September 6th, 2018, 6:06 pm
390....Curious have you found the issue yet or is it all good now its full of coolant....... :beergood:
390Express
Re: Hot Manifolds
Postby 390Express » September 10th, 2018, 1:25 pm
bud37 wrote:Source of the post 390....Curious have you found the issue yet or is it all good now its full of coolant....... :beergood:
Well, was good for about 6-10 hours of running at perfect temp after I added coolant. Then, out of the blue, last weekend it puked a shitload of antifreeze out of the motor, but I don't know from where? See new thread.
Users browsing this forum: No registered users and 99 guests
