Carver 356 RPM issues
- cpoint
- Has thanked: 208 times
- Been thanked: 26 times
Re: Carver 356 RPM issues
- Been thanked: 615 times
- Has thanked: 455 times
- Been thanked: 1671 times
Glad you finally got it solved and that you can get some boating done. Fingers crossed that the tanks won't be a constant headache.
- DCharles
- Vessel Info: 2001 Carver 326
As soon as you ever notice the throttles at differ positions it’s a sign the plugs are on there way out. Best to change dist cap and rotor as well. Also ensure plug wires are within resistance specs.
- cpoint
Viper wrote:Source of the post Just my two cents here; I mentioned before how important it is to go through a systematic diagnostic process which I see now didn't happen with your previous mechanic. Had he performed an injector flow test which is easy to do right on the engine, and compared the results to spec or simply to each injector, this problem would have been solved a while ago. This is the difference between throwing all kinds of money on parts and procedures in hopes that one of them will solve the problem, and performing proper tests that will point to the actual culprit.
Viper, Thanks. I know what you mean, unfortunately, due to my lack of knowledge in mechanics (know more now than before), they took advantage of it I believe. So far we put 9 hours since the last fix, and this is most we went trouble free, and it is fun not seeing tach go crazy, not to mention getting same power out from both engines. I too am hoping the tanks wont cause more issues, but at least we know now the issue was and most likely will be fuel injectors if it happens again, we'll just bite the bullet and get them cleaned. But we definitely enjoyed it last 3 days being a long weekend today we are getting bottom cleaned, so we can throttle up more later part of the week when we head out.
- cpoint
DCharles wrote:Source of the post Change the spark plugs on both engines!!
DCharles, mine are bit off, but I think the cables needs adjustment, they never been adjusted.
Users browsing this forum: No registered users and 43 guests
