370 Voyager 1993 Propellers
Tim Sperryn
Vessel Info: Carver 370 Voyager 1992/ 1993 model
Post by Tim Sperryn »
Hi
I'm seeking prop specs for the above boat with Cummins 300's?
ps: great to be part of CYO!
Re: 370 Voyager 1993 Propellers
Welcome to the forum.....is the boat new to you ?.....sometimes original prop specs from the factory sea trials could be misleading, especially for older boats that have thousands of pounds more stuff on board.
My guess , e mail Carver with your hull number and engine numbers and they may have the original specs for you.Also maybe someone here with the same combo can help......good luck man...
Welcome aboard. Hopefully a nother member with the vessel will chime in.
Been thanked: 492 times
Post by waybomb »
Welcome aboard!
Been thanked: 470 times
Post by RGrew176 »
Welcome aboard. Good luck in your propeller search. Good news is someone here will have an answer to your question.
Tim Sperryn
Thanks all, I’m currently unable to contact Carver as I suspect the UK on it’s way to medieval times...!
Tim, try contacting Pat Johnson via email. He should be able to help. Include your hull number in the email:
pjohnson@marquisyachts.com
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 414 times
Post by Cooler »
Tim - see my comments under Model Discussion category. 8-) er
Cooler By The Lake
Tim Sperryn
Many thanks for the contact!
Tim
