Engine room lights on my 356
- Rich W
- Vessel Info: 1993 350 Aft Cabin
Sandy's Riches - Location: Upstate New York
- Has thanked: 1 time
- Been thanked: 2 times
Re: Engine room lights on my 356
Of course, this means that they can charge me greatly for it. Oh well!! Thanks again.
Rich W
- Bentone23
- Vessel Info: 1996 Carver 355 Aft Cabin
454 xli TBI Crusaders - Location: San Francisco Bay
- Has thanked: 57 times
- Been thanked: 5 times
- Contact:
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
- Has thanked: 455 times
- Been thanked: 1671 times
Yes, engine room lights.Bentone23 wrote:Source of the post Is that what the switch that has the green lamp below it is for?....engine room lights
- Has thanked: 324 times
- Been thanked: 595 times
Unfortunately, I believe many items such as the water pumps, a/c pumps and battery chargers on these boats from the factory were not ignition proof.
Engine room lighting falls into a special category IMO. It's not enough for them to be simply ignition proof in a gasoline bay, they must be robust and not easily broken or damaged even in a diesel application. When I'm crawling around in an engine compartment with the lights on and working on a gasoline related issue or anything else for that matter, I don't want to have to worry about bumping into a flimsy fixture or live wire that could put me in a dangerous position. Even if ignition proof ratings aren't required for a given application, a non-marine assembly that comes with wire pigtails for example don't use marine wire and aren't built/assembled with the same considerations in mind. ALL engine bays require marine wire for more reasons than just their anti-corrosion properties. An unnoticed accidentally broken fixture, bulb, LED, wiring, etc. in a circuit that gets powered up later is an explosion hazard in a gasoline application and a fire hazard in ANY application.
