Rudder Synchronizer Gauge
- ronmar
- Vessel Info: 1993 350 Aft Cabin
- Has thanked: 21 times
I have a 93 350 Aft Cabin with rudder synchronize gauge that is not registering. It appears the sender unit is mounted on the rudder link rod under the aft cabin bed. I see 3 red wires as part of the harness. 2 are attached to the sender. The 3rd is not attached and simply coiled and tied off. Does not appear to be a connection where it would attach and assuming just an extra. All connections on the gauge itself are connected and the light comes on with instrument lights but not registering for rudder position.
Does anyone know how I should test and or repair?
- Has thanked: 268 times
- Been thanked: 1153 times
Re: Rudder Synchronizer Gauge
- Has thanked: 579 times
- Been thanked: 1210 times
- pepmyster
8.1 Volvo Penta
- Has thanked: 474 times
- Been thanked: 201 times
- Has thanked: 455 times
- Been thanked: 1671 times
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
amanphoto wrote:Source of the post Have you cleaned the connections on the sending unit on the rudder? If sending unit is bad it can be replaced for around $200.
That's a lot of $ for a sender. This is what I bought however you would need to check the resistance type you have as this model may not be compatible with your gauge. https://www.ebay.com/itm/Singal-Station ... 0005.m1851
Actually that is not true since I bought the gauge and sender in a package. Really only did this because I wanted white gauges when I redesigned my dash and electronics. https://www.ebay.com/itm/KUS-Boat-Rudde ... SwpOxaAWGK
- amanphoto
Users browsing this forum: No registered users and 94 guests
