spiral stairs install
- Cheryl
- Vessel Info: 1989 36' Carver Aft
- Vessel Info: 1978 Santa Cruz 2866
Moosehead Lake, Maine - Been thanked: 1 time
Re: spiral stairs install
If it's the last one I can offer a simple solution....
- Cheryl
- Has thanked: 53 times
- Been thanked: 426 times
Then when you bolt through, use a Marine Caulk, such as BoatLife or 3M 4200 or 5200. DO NOT USE SILICONE as a sealer or adhesive!
http://www.westsystem.com/ss/repairing- ... iberglass/
Now, IF the 4" distance from outside to inside has empty space (likely), then you can do the following. Cut a hole next to where you need to mount. Properly install an access deck plate (see link for examples). This will allow you to bolt securely to outer hull using backing plate and correctly sized bolts. The deck plate will be hidden by the stairs, but even if exposed- if properly installed- will look like any other fitting. I have done this on several boats for mounting after-market equipment, running new wire/accessories, etc.
http://www.beckson.com/screwout.html
Might work for your application......
Joe
