One Week as a 3807 Owner
- Has thanked: 269 times
- Been thanked: 1153 times
Re: One Week as a 3807 Owner
- Been thanked: 615 times
- buster53
- Been thanked: 262 times
I'm not saying you shouldn't be concerned, but if you have a bilge heater, just big enough to raise the temp in the bilge 10-15 degrees, you are more than covered.
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 38 times
- Been thanked: 11 times
- buster53
VicB wrote:Buster53, that’s just something I’ve never thought about. I’ve always gone through the whole 9 yards winterizing, but it’s always been trailerable stuff that’s stayed out of the water. Makes complete sense!!! What about plumbing? Just pour everything antifreeze in the drains for the traps and heads?
There's a big difference between a boat spending the winter out of water vs in water. I'm in VA. I have to be way more concerned about winterizing my boat when I haul for the winter. In water, I don't worry quite as much when we have a really cold snap for several days when the temps don't get above 20-25. The water will keep my bilge at least 10-15-20 degrees warmer than air temps.
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
VicB wrote:Source of the post Wow, this is exactly what I need! Great advice. What about winterizing? There is a permanently mounted engine compartment heater. Previous owner said he just uses it and closes all seacocks, covers the outer vent louvres with foil tape and puts a small heater in the center of the cabin on a low setting. It does get cold in north Alabama, and on rare occasions we might have teens or twenties at night. To get the boat closer to home, I will be moving to a new marina soon where it will probably spend the winter in an uncovered slip while I am waiting on a covered spot. Would love to know about anything specific about it being out uncovered as well. Thanks in advance, Vic.
Just up the Tennessee from me a fellow left his boat with city water on. The boat sank when a water line blew. So the advice above about disconnecting it is really important.
I live just north of you above Chattanooga and winterize every year. I waited last year until December. My cockpit shower was damaged and I had to replace the faucets. I have a Tempstick that measures the temperature in the bilge. My generator is in the back of the boat just in front of the rudder controls. It got down to 25 degrees twice last year at the generator. That temperature occurred even though I had a bilge heater running in the boat between the engines.
Two issues with it being uncovered. Check to make sure all of your drains are clean and operable in the cockpit and anywhere else exposed to rainwater. When it rains, check the portholes and and any other openings for leaks. Look in the bilge at the lowest point in the boat for water to ensure water isn’t getting into the boat.
Takes me about three hours to completely winterize with a friend so it isn’t a big deal to do that to be on the safe side.
I would get the exhaust problem fixed right away. That could be a dangerous situation.
- VicB
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 19 times
Midnightsun wrote:Source of the post Carver Club? CC, Canadian Club, Coincidence? https://www.canadianclub.com
too funny, was thinking the same thing! cheers!
Users browsing this forum: No registered users and 293 guests
