2006 Carver 36 MY port side prop spins in neutral
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 19 times
The dry dock inspection showed starboard prop turned freely (motors off, trans in neutral) while the port side prop was stiff to turn. The initial thought was alignment, but now I'm questioning the transmission clutches.
Would this indicate a bad clutch pack? I know nothing about the internals of these transmissions, assuming they are a Volvo Penta version of Hurth ZF. Are they same for BB vs SB V8's?
There is 217hrs on the port engine but 229hrs on the starboard, does running one engine more than the other damage the transmission?
Is this a common issue? is there a "simple" typical fix?
Does the whole transmission need to be removed to be serviced? or can it be serviced in place?
thanks in advance for your insights and comments as the wife and I are trying to avoid a large money pit issue.
- Been thanked: 1043 times
Re: 2006 Carver 36 MY port side prop spins in neutral
You could either have a valve problem that is pushing some pressure on the clutches or some warped clutches. Do you feel it change significantly when you actually put that engine in FWD? What happens when you put it in reverse? If the RPM on port drops lower than starboard in reverse, that might be a clue that the fwd clutches are still engaged. Running for a long time like that would be bad and overheat the trans, but since you rarely use rev you probably wouldn't have too much of a concern on that.
When it's in neutral and engine off, is there any noticeable drag on the port side vs the starboard side? That might tell you more if it's a warped plate issue.
- Has thanked: 579 times
- Been thanked: 1210 times
Regarding your money pit question.......considering what you have come across already, what do you think at this point ?
- Has thanked: 455 times
- Been thanked: 1671 times
- Cliffm
"the Condo"
Warped clutch pack steel plates, will need R&R to operate correctly. $2290.00 USD for complete trans, at FredWarner1.net, best price I was able to find.
Hatton Marine quoted same trans price, plus install, totaling $4260.00 USD
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 467 times
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
RGrew176 wrote:Source of the post Since you are getting one of the transmissions repaired I would consider at least having the trans fluid in the other transmission flushed and changed. When I had my port transmission rebuilt on my 3007 I had the mechanic change the fluid in the other one. I now know that both transmissions had new fluid put in in 2017. I plan to change the fluid every 5 years.
5 years seems like a long time to me. I generally do mine seasonally, if nothing else, to get the condensation out. I don't know if that is excessive, I boat around 60-100 hours per summer, but for less than $20 or so per side, seems well worth it.
Users browsing this forum: No registered users and 61 guests
