88 Carver ,Crusader engine swap?
rsims62
Vessel Info: 1988 Mariner 28ft
Has thanked: 13 times
Post by rsims62 »
HI All
New to me 88 carver 2897 mariner, HAs one bad motor, Wondering if I can swap a Mercruiser 5.0? Just engine. Bilge flooded.
I think its easier and cheaper then rebuilding the crusader. Will this work.. Both Inboards of course.
Rob
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: 88 Carver ,Crusader engine swap?
Post by buster53 »
Why not replace with a Crusader re-man? Crusaders have the reputation as being the better built motor.
Been thanked: 248 times
Post by mjk1040 »
I have 2 used 1986 Crusader 5.7L long blocks, had 1300 hours on them. Starboard need rod bearing replaced. I'm in upstate NY. Crated. Asking $1K for both!
rsims62 wrote:Qr Bbpost.....HAs one bad motor, Wondering if I can swap a Mercruiser 5.0?....
Rob, if you're simply asking if everything on the Crusader will bolt onto the Merc, unless the engine generation/variants are vastly different, I don't see why not but you want to get the same generation block or you could end up with dissimilar main components and a completely different power curve on port vs starboard sides. This can cause other problems which may affect the longevity of the engine on the other side or the new replacement. There are a few different variations so you may want to do some research before you commit to the Merc. This is why when practical economically and providing the block is in good shape, it's usually best to stick with the unit you have unless you know exactly what you're getting in the replacement. In a twin engine application, this is an important consideration.
I suspect you're in salt water, and if the Merc is from a salt water application, ensure it's closed cooled. Also make sure it wasn't a replacement engine at one time. In other words, was it used as a replacement before, and if so, was a "marine" engine used rather than an automotive one? They ARE different.
On that vintage of boat, you'll likely have a standard rotation and counter-rotation engine. In a straight shaft application, typically the port engine is a standard rotator. If the application incorporates a v-drive where the front of the engine faces aft, this could change the side where the standard rotating engine is placed depending on the v-drive model.
In short, it can be done but there's more to it than just looking for another 5.0L
rsims62
Post by rsims62 »
OK, I have the Starboard engine cranking, I need Belts, Can I cross reference the 2 and get them Local? I like to get it started tomorrow. Or Ill have to order and wait,
I have 2 part numbers 98210 Drive, and
Raw water 10258.
These are Chevy engines? correct. can I get them at any auto place? I just need to know what to cross it too?
I have a local guy with 2 crusader engines if I want them, running...but I'd like to try to get the one running for now...
thanks
rob s
Been thanked: 492 times
Post by waybomb »
Bring the belts with you and get the same size, cross section and length.
Ya an automotive place should be able to cross reference the belts or measure them up and get suitable replacements.
rsims62
Post by rsims62 »
Thanks Guys, Im bringing them and have crossed referenced them also.. AUTOZONE has them in stock!! wish me luck..
RS
Keep us posted :down:
rsims62
Post by rsims62 »
O Brother, DONT"T Shoot me, LOL..
So I go today and take a really good look at engines, NOT CRUSADER, 5.0 Mercruisers, Thunder bolt!!! What a DOPE IM!!Sorry guys..... THe PO said he had replaced them , I was so concerned about putting New Bilge pumps in I never looked at the Top of the engines... SOOOO , Im going to get the belts on tomorrow I hope, Its pouring here today, and either way, Im having it towed to my Slip and go from there.
At least I know what parts go too. So Ill be looking for Carb, Starter, Alternator. Disty.
