Thoughts on a 95 355
- chpsk8
- Has thanked: 27 times
- Been thanked: 75 times
I've been looking at a 95 355 that appears pretty clean. Has had some updates as far as furniture and carpet goes. Not perfect, but has those fun projects that I like to work on.
Any thoughts on what I should be looking out for that would be unique to the 355?
This one has 454's and I believe they are throttle body injected. He said they weren't fuel injected, but not carbs either. Impellers were replaced within the last year. When I started it, the port motor took a little longer to fill the muffler than the starboard side. Clean oil, didn't see any leaks, but haven't completely rolled around in the bilge to get to know them.
The genny started right away and appears to be used regularly. It was pretty much silent.
The bilge where the motors are was fairly clean. The shaft seals had a couple drips if even and have been replaced recently.
I've read about the Aux gas tank. The owner implied it's empty and not used. I hadn't read enough before that conversation so I'll probe more next time.
There was water in the bilge in the galley. It was clean water, so I'm assuming either AC condensation or plumbing leak. Is that common?
The heads are electric (push button on the wall). They sounded strong. I was really looking for vacuflush, but if it works, I'm ok if I know what to look for as far as maintaining. Are parts still available?
Where's the water heater, pump and water tank? Are they easy to see?
The hull looks really nice, no dock rash, reasonably polished. I did notice that there wasn't a storage compartment on the swim platform. Instead there was a place to store fenders. I'm thinking I could add a dock box with a pad to sit on.
The anodized aluminum around the windows was really faded. Not sure what options there are for making that deep black again. I've vinyl wrapped a lot of car parts, so maybe that's an alternative. 5 years is usually all I get with black though. Given the age of the boat and the state of the caulking I'm sure I'm in for some rebedding projects.
AC units were blowing cold, fridge was cold enough plugged into shore power to have ice cream.
There was a cooler in the main outside seating area where the little sink is. Is that normally a cooler, or is that an ice maker or mini fridge?
As I walked around to the bow I noticed some standing water in the port walkway towards the bow. It was a little orange so there's been some staining and that water is probably there normally. Is that a standard "design feature"? Any remedy?
We're looking for something with good bones and plan to have this one until the kids move on in 8-10 years. Our current boat we've had for 5 years and it's time to step up.
Any advice on what I need to look at would be excellent. Thanks!
