2006 Carver 36 MY Generator use
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 19 times
Our current temporary moorage only allows a single 30amp connection, so we have been forgoing the A/C heat pumps, all three, and just using an efficient ceramic heater in main salon. we'r moving in January to a Marina w/50amp service.
I have read numerous posts here, along with the PDF Owners manual (we're fist time Carver Yacht owners, recently acquired) but i'm still confused If I can "safely" run 110V shore power on one panel and simultaneously run generator to run all three A/C units without issues on the other panel? The main panels switch is for AC power, but doesn't distinguish between Generator or shore power. Those "in-the-know" please advise.
What happens to the "un-used" A/C shore power cord ? is the cord "back-fed" and the connection end now "hot"? Do I need to get a cover for the shore side male end in order to "safely" to stow it under the stairs?
Thanks,
Cliff & Beth Mathison
- Has thanked: 268 times
- Been thanked: 1153 times
Re: 2006 Carver 36 MY Generator use
As for shore power vs generator. You cannot function a combination of both. If you use the generator then shore power gets disconnected at the panel via the selector switch or sometimes automatically via an automated solenoid. Regardless of how it is done they are never combined. There is never any back feed to the exterior shore power prongs as the switching is done at the panel.
- Has thanked: 579 times
- Been thanked: 1210 times
- Cliffm
"the Condo"
bud37 wrote:Source of the post If you have two shore power inlets to the boat, why not just run your one 30 cord and split it to both inlets....that way you can portion out your power until the move, they have adaptors for just that.....done it for years....
we have the adapter, it trips the 'old dock" wiring, with adapter on, both panels on, but no A/C on, we have power, but as soon as we enable (1) or (3) A/C units, the shore power breaker trips. Doesn't trip with panel one only and ceramic heater, unless hot water tank on and range on at same time.
This is what led to my plugged in but running genny question.
- mjk1040
- Been thanked: 242 times
PS>I have also seen a bad neutral at the shore power supply give u tripping problems along with an inadequate amp supply at the shore power pedestal!
Cliffm wrote:Source of the postbud37 wrote:Source of the post If you have two shore power inlets to the boat, why not just run your one 30 cord and split it to both inlets....that way you can portion out your power until the move, they have adaptors for just that.....done it for years....
I guess my question is what possibly could be consuming so many amps? I know for a fact a water heater and AC not to mention charger, lights, fridge can easily run off a single 30a breaker . That being said you will get a 50a connection after the move which is only 20a more than what you have now to run 3 units. Point is something is amiss. I have a feeling your 30a shore power breaker at the pedestal is actually a 20a or the breaker is old and performing like a 20A.
- Been thanked: 1043 times
Often, it's just the compressor start-up spike that blows the breaker. Once you get past that, you could turn the water heater back on and let it run. I've thought about putting in a relay (contactor) that would disable the water heater when the A/C compressor is running as a way to run on a single 30A circuit, but still haven't implemented that.
- Has thanked: 455 times
- Been thanked: 1671 times
- Cliffm
"the Condo"
moved to Elliott Bay Marina, twin 30A connections per slip. Plugged both cables in, powered up both panels, turned on all three AC units in auto mode (one at a time) took a bit but got interior up to 70F. It appears that running front stateroom blows into galley area, so we ran both aft and front stateroom AC units, with salon off and kept everything comfy and drawing only 10A.
Users browsing this forum: No registered users and 118 guests
