Cigarjim - I would suggest actually measuring that slip before passing on a great boat, or moving up 5' in slip for just 7".
Looking at the model 396.
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
Re: Looking at the model 396.
Waybomb - are your slip lengths true to length? The 396 is just 7" longer than the slip, if it is. In this area, the slips are a little longer than stated length because so many people go stern first. With stern in, the entire slip can not be used because of the triangle of support struts, so some marinas do not count that space.
er
Cooler By The Lake
- Been thanked: 492 times
Cooler, I own the two slips in front of my condo and a slip in the yacht club. I just know the marinas in the area very well.
Cigar, there's always pier 1000 or Brian's marina.
I believe there are a few slips for rent at SJIYC next to anchors way marina. I have a slip there but it's rented out for next season. 45 x 25. $1600/season.
I would not recommend anchors way.
- Sadey
- Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Current owner 1989 60’ Hatteras MY with 8v92 Detroit’s
Benedetto - Location: Racine Wisconsin/Ft. Lauderdale
- Has thanked: 4 times
- Been thanked: 29 times
Fair market on the survey was $96,000.
Thank you for the help!
Dave & Trina
Dave & Trina
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
- Cooler
Yep, the 390's also had the extended bow pulpit. The 396 originally inquired about, does not. LOA on that model 396 is 40'7", taken right from the spec sheet.
Sadey, you did really well! Good for you. Can't wait to see her in Door County next season.
Cooler By The Lake
