Riviera 2850 drain plugs
tomtomterrific
Vessel Info: 1986 carver riviera 28
Has thanked: 14 times
Post by tomtomterrific »
Ahoy Mates!
Re-Commissioning my '85 Riv for the first time. Any tips on how top remove the drain plugs?
They are the brass (I think) through hulls, with the 8" "T" handle. They are in tough locations to access, under the aft sink and under the water tank. I can get pliers on them but I can't break them loose. I don't want to twist the handle off.
Appreciate any tips.
Cheers!
Cap't Tom
Been thanked: 248 times
Re: Riviera 2850 drain plugs
Post by mjk1040 »
Try some liquid wrench penetrating oil! Or Coke a Cola! Then put some anticized on them.
Been thanked: 492 times
Post by waybomb »
You've tried loosening it; try doing the opposite - a little tighter at first. Then looser. Rock it back and forth.
A heat gun from the bottom first. Get it nice and warm.
It may work.
ps - I believe your model designation is 2807.
