44/444 AC control panel power light
Huckleberry
Vessel Info: 2007 Carver 36ss .
2005 Carver 44 CPMY
Has thanked: 18 times
Been thanked: 6 times
Postby Huckleberry » March 29th, 2019, 1:44 am
On my Carver 2005 Carver 44 CPMY in the AC control panel , the shore power available lights are not lighting up .
Shore power is hooked up and everything is working fine EXCEPT the lights that should light up when shore power is on are not .
Any ideas ?
Huck
Has thanked: 269 times
Been thanked: 1155 times
Re: 44/444 AC control panel power light
Postby Midnightsun » March 29th, 2019, 6:12 am
These lights tend to be on 24/7 when the boat is plugged into shore power. The bulb is probably burnt out. Not sure what you have in yours but do know Bayliner used neon tubes that needed to be soldered in place, a pita to change and find but doable. When you do find what you have please post back as I am sure many here have the same issue but just leave it or do not even realize it is burnt out.
Been thanked: 617 times
Postby g36 » March 29th, 2019, 10:19 am
i dont have you boat and i agree with the above response .however could they be reverse polarity indicators which would not come on unless there is a reverse polarity condition.
Has thanked: 582 times
Been thanked: 1214 times
Postby bud37 » March 29th, 2019, 10:31 am
Those little indicator lights ( red and green ) if they are the same as ours are so dim they can only be seen dimly in the dark .....I need to replace ours as well I guess......
FWIW.....The above is just my opinion..... :popcorn:
Brazil
Hugo
Has thanked: 2 times
Been thanked: 23 times
Postby Hugo » March 29th, 2019, 1:39 pm
Easy to replace. Contact Carver and ask for spares. I've done it on mine twice...
Return to “Electrical”
