Volvo Penta TAMD74P-A Fault Code 3.3
golgi
Vessel Info: Carver 530 Voyager Pilothouse
Has thanked: 19 times
Been thanked: 6 times
Post by golgi »
Hi all... Prepping the boat for launch after a long layup. Port motor turned over great. Starboard gives me a 3.3 fault. Can't clear it. The motor gives a clunk when I try to crank it but that's it. Thoughts? Anyone know what a 3.3 is? It's not in the manual. Thanks in advance
Re: Volvo Penta TAMD74P-A Fault Code 3.3
Can't help with the 3.3 fault....but considering a long layup, how are the batteries, all battery terminals clean and tight.....grounds all ok.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 211 times
Post by pepmyster »
Have to agree, find out why it's not turning over, batteries...starter....grounds....
golgi
Post by golgi »
Batteries good, fully charged and load tested. All terminals cleaned and tight.
pepmyster
8.1 Volvo Penta
Fresh water boating
Post by pepmyster »
Can you turn the engine over by hand with a wrench or socket?
golgi
Post by golgi »
False alarm. Traced the the entire loom and found the coolant temp sender was not connected. It does appear I need to wire in a new connector (broken retainer clip) but all is good otherwise. Thanks for the quick responses!!
golgi wrote:Qr Bbpost False alarm. Traced the the entire loom and found the coolant temp sender was not connected. It does appear I need to wire in a new connector (broken retainer clip) but all is good otherwise. Thanks for the quick responses!!
So does the engine turn over and run now ? Maybe you know but if not there is a site called boat diesel that a lot of diesel guys recommend.
Been thanked: 248 times
Post by mjk1040 »
Makes you wonder why it's broke?
