Hope the picture will post. this is in the forward cabin of the boat we just bought, it appears to be an old water stain that I believe may have came from a one time or slow time event. It both feels and smells like an old event. What could cause a one time event like this or do I have a problem ?Welcome to Carver Yachts Owners Forum
forward cabin stain,3607 1987 model
- RWS
- Vessel Info: 1987 3607 aft
- Has thanked: 28 times
- buster53
- Been thanked: 262 times
Re: forward cabin stain,3607 1987 model
Just a guess, but I'm thinking the boat saw some heavy water and it splashed up into a gap in the hull-deck joint.
- Has thanked: 324 times
- Been thanked: 595 times
I don't think that is a one time stain.
Look at areas above for places where water could intrude, such as deck railings etc. Bounce a bit on the decks and see if they flex. Keep in mind, water can travel quite a ways until it finds it way into the cabin.
- RWS
tomschauer wrote:Source of the post I don't think that is a one time stain.
Tomschauer, I plan to reset all the rail and cleat screws with 3M products. just thinking if this is a consistent problem the glue would have let lose and the covering would be falling down.
- Has thanked: 71 times
- Been thanked: 1053 times
I have the same boat, but older ('83 3607). I don't have that problem, but I'd wonder what's at the most forward part of the stain. That part of the deck is still the 'flair' from the bow, do you could have something getting in at one of the forward cleats or deck pipes and following the flair down to where that liner is.
- RWS
km1125 wrote:Source of the post I have the same boat, but older ('83 3607). I don't have that problem, but I'd wonder what's at the most forward part of the stain. That part of the deck is still the 'flair' from the bow, do you could have something getting in at one of the forward cleats or deck pipes and following the flair down to where that liner is.
By deck pipes, do you mean gas or water fills? the water fill cap does not screw on tight. Only a a turn and has no o-ring. Do you think water is getting in there and running forward?
RWS wrote:Source of the postkm1125 wrote:Source of the post I have the same boat, but older ('83 3607). I don't have that problem, but I'd wonder what's at the most forward part of the stain. That part of the deck is still the 'flair' from the bow, do you could have something getting in at one of the forward cleats or deck pipes and following the flair down to where that liner is.
No, I'm thinking more towards the bow. The deck pipes I'm talking about are for chains or ropes and are storage for when they're not in use. I have two on the deck right behind the bow pulpit (port and starboard) and the go into that little area forward of the V-berth.
How far forward does the stain go?
- Has thanked: 270 times
- Been thanked: 1157 times
Had something similar to that on another boats monkey fur. Definitely water intrusion. I used some powdered oxy clean mixed with warm water and patted it down wit paper towels, with persistence it completely disappears. In my case i also though it was a one time event until it came back again, sealed some more screws and stuff, cleaned it up and it eventually came bak once again. The irony is I finally did find the leak which was quit some distance away, a simple forgotten screw in the windshield frame which I found when I removed the sealing strip. This is not your problem but figure I should mention it. Point is it cleans up well with oxy clean.
- RWS
km1125 wrote:Source of the postRWS wrote:Source of the postkm1125 wrote:Source of the post I have the same boat, but older ('83 3607). I don't have that problem, but I'd wonder what's at the most forward part of the stain. That part of the deck is still the 'flair' from the bow, do you could have something getting in at one of the forward cleats or deck pipes and following the flair down to where that liner is.
Not too far past what the picture shows, but is also on the other side, just not as bad.
- RWS
Midnightsun wrote:Source of the post Had something similar to that on another boats monkey fur. Definitely water intrusion. I used some powdered oxy clean mixed with warm water and patted it down wit paper towels, with persistence it completely disappears. In my case i also though it was a one time event until it came back again, sealed some more screws and stuff, cleaned it up and it eventually came bak once again. The irony is I finally did find the leak which was quit some distance away, a simple forgotten screw in the windshield frame which I found when I removed the sealing strip. This is not your problem but figure I should mention it. Point is it cleans up well with oxy clean.
Thank you, I will try oxy clean.
