forward cabin stain,3607 1987 model
RWS
Vessel Info: 1987 3607 aft
Has thanked: 28 times
Post by RWS »
Hope the picture will post. this is in the forward cabin of the boat we just bought, it appears to be an old water stain that I believe may have came from a one time or slow time event. It both feels and smells like an old event. What could cause a one time event like this or do I have a problem ?
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: forward cabin stain,3607 1987 model
Post by buster53 »
Just a guess, but I'm thinking the boat saw some heavy water and it splashed up into a gap in the hull-deck joint.
Post by tomschauer »
I don't think that is a one time stain.
Look at areas above for places where water could intrude, such as deck railings etc. Bounce a bit on the decks and see if they flex. Keep in mind, water can travel quite a ways until it finds it way into the cabin.
RWS
Post by RWS »
tomschauer wrote:QR_BBPOST I don't think that is a one time stain.
Tomschauer, I plan to reset all the rail and cleat screws with 3M products. just thinking if this is a consistent problem the glue would have let lose and the covering would be falling down.
Been thanked: 1114 times
I have the same boat, but older ('83 3607). I don't have that problem, but I'd wonder what's at the most forward part of the stain. That part of the deck is still the 'flair' from the bow, do you could have something getting in at one of the forward cleats or deck pipes and following the flair down to where that liner is.
RWS
Post by RWS »
km1125 wrote:QR_BBPOST I have the same boat, but older ('83 3607). I don't have that problem, but I'd wonder what's at the most forward part of the stain. That part of the deck is still the 'flair' from the bow, do you could have something getting in at one of the forward cleats or deck pipes and following the flair down to where that liner is.
By deck pipes, do you mean gas or water fills? the water fill cap does not screw on tight. Only a a turn and has no o-ring. Do you think water is getting in there and running forward?
RWS wrote:QR_BBPOST
No, I'm thinking more towards the bow. The deck pipes I'm talking about are for chains or ropes and are storage for when they're not in use. I have two on the deck right behind the bow pulpit (port and starboard) and the go into that little area forward of the V-berth.
How far forward does the stain go?
Post by Midnightsun »
Had something similar to that on another boats monkey fur. Definitely water intrusion. I used some powdered oxy clean mixed with warm water and patted it down wit paper towels, with persistence it completely disappears. In my case i also though it was a one time event until it came back again, sealed some more screws and stuff, cleaned it up and it eventually came bak once again. The irony is I finally did find the leak which was quit some distance away, a simple forgotten screw in the windshield frame which I found when I removed the sealing strip. This is not your problem but figure I should mention it. Point is it cleans up well with oxy clean.
RWS
Post by RWS »
RWS wrote:QR_BBPOST
Not too far past what the picture shows, but is also on the other side, just not as bad.
RWS
Post by RWS »
Midnightsun wrote:QR_BBPOST Had something similar to that on another boats monkey fur. Definitely water intrusion. I used some powdered oxy clean mixed with warm water and patted it down wit paper towels, with persistence it completely disappears. In my case i also though it was a one time event until it came back again, sealed some more screws and stuff, cleaned it up and it eventually came bak once again. The irony is I finally did find the leak which was quit some distance away, a simple forgotten screw in the windshield frame which I found when I removed the sealing strip. This is not your problem but figure I should mention it. Point is it cleans up well with oxy clean.
Thank you, I will try oxy clean.
