AC discharge thrull hull intererior acees
- mjk1040
- Been thanked: 248 times
Re: AC discharge thrull hull intererior acees
Our 1998 doesn't have that cabinet door behind the head? The sink drain is only singled clamped because it has no pressure on it, it's a gravity exit line. The other three are all pressure feeds, shower sump, A/C cooling and aft bilge pump. Does that cabinet bottom unscrew and come out, will that gain you access to them thru hauls? Can you post a picture of the cracked thru haul? I still think flex sealing it and see what happens. That aft cabin night stand cabinet does come out, can a skinny person reach them from that access point? Under the shore water inlet there is a 6" inspection portal, take a look in there back toward the thru hauls, would you be closer by putting another inspection hole on the back wall of the swim platform to reach the thru hauls or will you run into the aft bulk head wall before reaching the thru hauls? Wonder what access you would have if you removed the head? Might be below the thru hauls! Keep us posted and good luck!
Mike
