Carver 41 CMY Questions
- bobcinga
- Vessel Info: 2006 CMY 41
- Been thanked: 4 times
We recently purchased a 2006 Carver 41 CMY. I've read in a couple of post that the stairs pull out to allow greater access to the engine area, but can't figure out how to get them out. I read in another post about removing 4 screws but can't find any. Another post said just pull straight out. They don't appear to budge no matter what I do.
My second question relates to aft salon. Facing the bow on the starboard wall there is a standard light switch and another selector switch. What do these control?
Lastly, has anyone replaced their clarion DVD players. All 3 on our boat are not working. Ant suggestions for a replacement?
Thanks!
Thanks!
Re: Carver 41 CMY Questions
It does pull straight up, no screws. Locate yourself on the upper floor area and get your fingers under the carpeted lip pulling upwards, takes some wiggling moving from back to sides and some strength but it does come out. You do need to move the couch out of the way as the corner just catches it by a couple of inches.
I think you are referring to the aft cabin? If so the switch is the ceiling light and the rotary selector for radio speaker volume control in the aft
I replaced mine except in the forward berth however the install was rather elaborate as can be seen in my pictures. That being said, any RV/automotive style DVD will work as a direct replacement.
Thanks!
Congrats on the acquisition, nice boat and welcome to the forum.
Take a look at the pictures in my signature as I have a substantial amount of modifications done. Some may interest you.
Thanks!
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 21 times
Han's provided excellent details, I just wanted add our 2006 36MY has had both TV's replaced w/Flat screen LED's. Teh main salon clarion DVD player also would NOT function, so we went to Walmart, bought budget HDMI BlueRay player $49USD and hooked up. we may replace the clarion unit in future.bobcinga wrote:QR_BBPOST We recently purchased a 2006 Carver 41 CMY. I've read in a couple of post that the stairs pull out to allow greater access to the engine area, but can't figure out how to get them out. I read in another post about removing 4 screws but can't find any. Another post said just pull straight out. They don't appear to budge no matter what I do.
Thanks!
Another thing worth mentioning is many of todays home electronics work from 12vdc but they use a wall wart to convert the 110v . In fact the DVD players I used are Sony of the household variety. cool thing is many of these have netflix and other streaming services built in so you get those also. Trick is to look at the wall wart and see what voltage it is supplying. if it is 12v it is a simple as cutting off the wart and hooking up directly to 12v battery power.
Same 110v/12v thing for my Samsung TV in the Aft cabin.
- bobcinga
Thanks everyone for the responses. Interestingly I found that when you lift the steps from the salon from the front (that is you facing the stern, the steps just slide right out. However, trying by lifting at the rear standing in door of main cabin facing the bow, they don't even budge!
Just finished installing 3 new blue ray DVD players and the second new television (in the rear stateroom. Glad that is done!
Those little projects seem little but once you are in the thick of things they get rather involved. Glad you got this part done.
- cmlrfp
- Vessel Info: 2008 41 CMY
- Has thanked: 2 times
I have the 2008 41 CMY and looking for a refrigerator for the cockpit!!!
Any recommendations from anyone?
Robert
Robert
https://www.westmarine.com/buy/isotherm ... ecordNum=1
I bought this one last year to replace my icemaker. The icemaker worked fine but was not really useful. I can fit about 40 12 ounce cans in this, and it keeps them very cold. If I set it above five, the cans (beer) on the top shelf will freeze even in 90 degree outdoor temps.
WM had a 20% off sale last year so I believe I paid just over 800 with tax. Looks like the base price is up a bit this year. But i belive it was worth what I paid and maybe a bit more? Ice cold beer, priceless!!!
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Nothing beats a cold drink on a hot day.
The deciding factor will be space. That being said the options at the time were ice maker, fridge or nothing. I would assume any fridge which is ice maker size will function. The unit used by Carver in 2007 was an Indel CR049NV369. The 49 in the model number is the size however Indel is now Indelwabasto and just to confuse you a little more the refrigeration department is called Isotherm but this looks identical to the one Carver put in mine. https://www.indelwebastomarine.com/int/ ... 9-classic/
Double check cutout dimensions as they may have changed before ordering.
