trim tab controls
rjr
Vessel Info: 440 MY
Has thanked: 25 times
Been thanked: 9 times
trim tab controls
Postby rjr » May 18th, 2019, 2:12 pm
Has anyone changed the controls for the trim tabs? I have the little buttons and have purchased the rocker type controls. Looks like the hole for the rocker set may be a little bigger than the existing opening. True?
Also, is there a trick for removing the base for the button controls?
Thanx in advance.
Has thanked: 579 times
Been thanked: 1210 times
Re: trim tab controls
Postby bud37 » May 19th, 2019, 6:14 am
Who is the maker of the tabs?
Been thanked: 1043 times
Postby km1125 » May 19th, 2019, 8:26 pm
I assume these are Bennett tabs? I've done the switch twice, once on an older boat and once on the bridge on the one I have now. I don't recall having to make the hole larger, but it's possible as it's been years since I did it.
I definitely prefer the rockers over the push buttons. I still have the push buttons at my lower station, but mostly I'm up on the bridge. A friend of mine made a machined aluminum cover for the button style that looks really nice.
As to your other question about removing the base.... I don't recall it being an issue. I thought you just took the cover off and there were a couple screws holding the assembly down. Next time I'm at the boat I can take a better look though.
rjr
Vessel Info: 440 MY
Postby rjr » May 22nd, 2019, 6:08 pm
bud37 they are Bennett tabs.
rjr
Vessel Info: 440 MY
Postby rjr » May 22nd, 2019, 6:14 pm
Thanx. Will give it a shot tomorrow.
Has thanked: 324 times
Been thanked: 595 times
Postby tomschauer » May 22nd, 2019, 11:13 pm
I have the rocker type switches. I seem to use my tabs maybe twice per year. Once before launch to make sure they work and maybe once more if I have more than 8 people on the boat and they all move to one side while I am on plane. Otherwise my boat seems to run pretty flat, and any tab actually slows me down and uses more fuel according to the flow scan.
rjr
Vessel Info: 440 MY
Postby rjr » May 26th, 2019, 1:01 pm
Well 2 things - 1) I attempted the switch and it turned into a goat rope. In order to get the cover off, I had to break it. The base is coming off in pieces. No screws but apparently lots of glue. Then I found out I could pull the rubber button up but in doing so the bayonet type connectors disengaged. When I saw that one wire was connected to both down switches and after looking at the replacement unit, I called the electronics guy. More later.
2)Tom - of it uses more fuel! It's like a penalty for attempting to get the boat to perform properly.
rjr
Vessel Info: 440 MY
Postby rjr » May 30th, 2019, 8:45 pm
So I found out the cover was held in place by a single bolt accessible from under the console. Who knew? And why would that method of fastening be used? The rocker base is held in place by four screws inserted from the TOP! Needed to enlarge the opening minimally and the wiring was straightforward.
Postby bud37 » May 30th, 2019, 8:56 pm
Well that sounds about right....there are no straight bolt ons without some form of engineering near as I can tell.....the bright side , now you get to find out if the tabs make a difference in performance.....
Return to “Electrical”
