1998 Carver 400 CMY - Raw Water SeaCock Location
TheMissBToo
Vessel Info: 1998 Carver 400 CMY
Post by TheMissBToo »
Hi - I have the drawing in the manual, but can't seem to find the raw water seacock. Ideas? Thx.
Re: 1998 Carver 400 CMY - Raw Water SeaCock Location
Welcome to the forum....G Bay huh......little more info from you could help the guys......what seacock, engines port or stbd......generator.....air cond... gas or diesel.....etc.
You in yet ??
TheMissBToo
Hi - Yes we were launched May 10. Cold but all good. I can't find the raw water seacock. Shows as port side aft the engines ... but can't seem to find it.
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Post by AaHubb »
It looks like that seacock was for an optional raw water washdown. If you don't have one you won't have that seacock.
..Aaron
'99 404 CPMY
SeaDragon
If you're talking about the raw water washdown option, it was an option and you may not have it. Do you have a faucet beside the upper aft deck sink cabinet? It'll be close to the floor. Short of that, turn on your fresh water pump, and try all the faucets you can find on the upper and lower decks, bow, etc. if you don't get water out of one of them, it may be a raw water faucet. If you have the option, you should have a breaker for the pump on your 12 volt main panel. As Aaron mentioned, the seacock is usually behind the port engine close to the port stringer. You should be able to see it from the center engine hatch or remove the aft port corner hatch. If you have an access hatch in the wall of the aft cabin close to the floor towards the port side, in front of the bed, behind the port engine, you can get to the seacock and pump from there too.
TheMissBToo
Thanks Viper, found it! Your instructions were bang on.
:down:
Don't want to miss winterizing that!
