Weird Wire
- Craig_B
- Vessel Info: 1988 Carver Santego 3067
- Has thanked: 144 times
- Been thanked: 13 times
Weird Wire
This might be a weird question........
So I was poking around finding out what does what in our new to us 1988 Santego.
Under the galley sink is an inverter with a single orange "extension cord" plugged into it.
I followed the wire down the starboard side until it disappeared and I have no idea what its for or where it goes.
If I turn off the inverter or unplug the orange plug nothing changes.
I think this is probably a long shot but does anybody have any idea what it may be for?
https://www.flickr.com/photos/giarc_dranrab/albums/72157707558217844
The rest of our picture albums.
- buster53
- Been thanked: 261 times
Re: Weird Wire
- buster53
Re: Weird Wire
- buster53
Re: Weird Wire
- Craig_B
Re: Weird Wire
I can only see the male end of the orange "extension cord" the other end disappears into the boats interior.
Its a mystery.
All other outlets etc still function with inverter turned off or unplugged.
I guess I will keep searching for the other end of the orange plug.
- Craig_B
Re: Weird Wire
buster53 wrote:Source of the post Is the inverter connected to your batteries
Yes. Two big cables attached. One red one black.
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Weird Wire
My guess , the extension cord is plugged into an outlet behind a cabinet, maybe where the fridge plugs in or micro etc........let us know what happens, remember to be careful when you have an inverter,... when you think the power is off that thing can be powering up the boat, double check with a tester....
Fyi....if that is actually an extension cord, that is a NO,NO.....if all works maybe get some marine cable and fix that up.
- Been thanked: 1043 times
Re: Weird Wire
If it's larger, say 1000-1500w, then I'd suspect it'd be for a microwave and you could look behind the microwave to see if there's an extra orange plug for that purpose.
- ColRon
- Has thanked: 77 times
- Been thanked: 153 times
Re: Weird Wire
“Escape Plan”
Murray, KY
- Craig_B
Re: Weird Wire
The inverter is 1500 watts.
This orange cord runs starboard to the stern which is toward the a/c unit. Its under the starboard couch.
However when the a/c breaker is off the a/c still does not run. Its possible this cord may have at one time ran the a/c but no longer does.
Either way it seems this cord is out of place and doesn't belong.
Next time I'm really bored I will see if I can find the other end.
Users browsing this forum: No registered users and 79 guests
