Need assistance in installing A/C unit
wxb167
Vessel Info: 1986 Carver Mariner 32
Post by wxb167 »
Hello:
I have a 1986 Carver Mariner 32 and I would like to install an a/c unit. However, I'm a bit stumped - would you know where do you root the water line from the pump to the a/c unit?
Any help would be appreciated.
Thanks,
Ian
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: Need assistance in installing A/C unit
Post by buster53 »
Not an AC guy, but I would think you want the AC water pump about as close to your thru hull as possible, and then look for the shortest, most logical run from the pump to your AC unit. map out everything...where to mount the AC unit, water line runs, electrical runs, duct work, pump location, thru hull location. What is the easiest, best way to go.
gotjeepzj
Vessel Info: 1986 Mariner 3297
Has thanked: 2 times
Post by gotjeepzj »
Does it have A/C now? Carver 32 what? I have a 3297 Mariner.
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Post by tonyiiiafl »
Pump should have the least amount of suction distance from sea cock to pull. It can push water better than suck it it in.
