Volvo QS BP1200 bow thruster replacement
ilbacio
Has thanked: 3 times
Post by ilbacio »
I need a bit of help.
My Volvo QS BP1200 Bow Thruster is dead and Volvo no longer makes this thruster nor can I find a source of parts to repair it. Does anyone know if there is a suitable replacement by another manufacturer that will not require a major retrofit?
Thanks for any help on this.
Been thanked: 248 times
Re: Volvo QS BP1200 bow thruster replacement
Post by mjk1040 »
What do you mean it's dead? Is a switch or relay gone bad? Can the motor be removed and rebuilt? Maybe an automotive starter rebuild shop can bring it back to life!
Alaska 530 Voyager
Has thanked: 42 times
Been thanked: 36 times
Post by Alaska 530 Voyager »
I'm looking forward to seeing more input on this. I also have the Volvo Penta QL BP 1200 Thruster. I lost the relay on mine a few years back, it was over $600 to replace and very hard to find. I have a spare reseal kit leftover for mine. I'm hearing no parts available as well. Dave
Really depends on the model and the part that's needed. A lot of the stuff is NLA but I've gotten lucky a few times just doing a google search. Volvo showed no gear legs in stock for a particular model but ended up finding me one at an overseas dealer, I think the dealer was in Australia. It took all summer, but it eventually came in.
Haven't had to retrofit one yet but even if the tunnel was the same diameter, it's likely the bolt pattern for the leg would be different so some fiberglassing there in all likelihood, and the models I've worked on utilize proprietary control boxes not used for any other brand that I'm aware of. Even if there were a brand with similar hardware, the controllers are probably outdated now anyway. Between that and different cabling, helm controllers, etc., you're basically looking at a new install save for the tunnel install from scratch.
Having said all that, "dead" is a pretty generalized statement. It could be something complicated and expensive and NLA, or it could be something simple that's readily available. Some parts may be generic that can be substituted with a part from an electronics supplier, as Mike pointed out, motors can be repaired. What component has failed and how did you reach that conclusion?
ilbacio
Post by ilbacio »
Not sure what is wrong. It appears to be seized. I just bought the boat and a high water mark in compartment housing the thruster motor indicates that the motor was partially submerged at some point. Since Volvo no longer makes this unit nor any of it's parts, I thought i may be be prudent to replace it with a new popular brand thruster to make it easier to maintain or repair in the future. I have read that maybe IMTRA CORPORATION Side-Power SE Series 130kg Thruster may be a unit that can replace the BP1200 with minimal work.
The guys at Imtra are great. I deal with them all the time. They're certainly very helpful. Talk to Peter Nollet. If I remember, I'll look into your Volvo unit next week for available parts and ask one of the guys at Volvo if there are any major parts still available including from overseas dealers....you never know. Having said that, nothing about that system is cheap and given its age, something else may fail later. Sometimes the best solution is to upgrade to something newer and start fresh in the hopes that you won't have any failures/expense for another 10 years.
I took a look at the parts still available for that unit. Most are listed as obsolete. While the motor is listed in the bulletin of parts no longer available, it is still an active part number in the system that shows as currently out of stock with a back order status. This usually indicates the possibility that it may still be obtainable. Parts that are no longer available usually have a "deleted" status or will simply not show up in a part inquiry which indicates an invalid part or part that is no longer available. Having said all that, the current list price for that motor is $8123 Canadian, just for the motor!! Even if it were readily available at this time, I'd be recommending upgrading to a whole Side Power system for that price.
Audacia
Vessel Info: 2008 Marquis 59
Been thanked: 4 times
Post by Audacia »
Is anyone here willing to sell their old BP1200 if you have replaced it or know someone that would? I need a couple of spare parts (mainly in the underwater gear portion). Thanks.
Sgodfrey
Vessel Info: Carver 450 Voyager
Been thanked: 9 times
Post by Sgodfrey »
Hello -
I have BP1200 but I think there is an issue in the gear box. I have not taken that apart but suspect an issue between the motor (which spins freely) and the props that turn with a little resistance. Is anyone interested in making an offer for the unit as is. I am considering posting it either as a unit or parts on eBay?
Audacia
Post by Audacia »
I would make you an offer for the gear box, but without knowing what is exactly wrong with it...it is a major gamble. The guy above looking for a motor should hop on this.
Please confirm (because other will want to know) 12V or 24V and year of manufacture. You may want to include a photo of the QL label on the motor housing.
