1987 3607 Batteries, charger and switch
- RWS
- Vessel Info: 1987 3607 aft
- Has thanked: 28 times
- Has thanked: 579 times
- Been thanked: 1210 times
Re: 1987 3607 Batteries, charger and switch
Really the battery switch is doing what it is supposed to.....when you turn the control you are telling the boat where to get its power from, bank1/bank2 or both....it is 12volts no matter what.....until you turn it to off, then that should shut the boat down except for the bilge pumps and a few things that may be hard wired to selected banks.
Maybe test the batteries, ....what are they, type and how big/ group size.... amp hour reserve
- RWS
I think charger change is a must. I dont have brand of battery info here with me but I know 2 are gel and it may not be good to have different type batteries . Shouldn't one setting on the switch cut power from the house besides OFF postion? with 4 batteries will I need a 4 bank charger?
- Been thanked: 1043 times
Originally the 1-2-all-off switch would just switch between the two starting banks and provide power to both engines and all house loads with whatever selection you had (one or two or both or none).
Since then I wired up a dedicated switch for the house batteries, so now the 1-2-all-off just controls what goes to the engines and I have another 1-2-all-off for the house. If you switch the house to "2" it connects to the engines so it essentially works exactly like the original switch. If you switch it to "all" it will connect the house bank to whatever is selected on the engine switch, so you can connect all the batteries in parallel for charging or supplying loads.
The best way to figure your switch arrangement is intrusive but conclusive. Disconnect all the batteries (making sure you protect the ends so you don't short anything out). Then put the switch on "1", turn some loads on (some lights would be fine, or a blower), then connect each bank one at a time by itself and see which bank ends up powering the load. Then switch to "2" and do the same thing. You can try and follow wires if they are accessible too and draw a wiring diagram. Your diagram will be different than the Carver stock one because theirs only had two batteries (if you bought the "dual battery" option!).
And I definitely agree that if you have some GEL and some of other types (flooded or AGM) then you need a different charger. You could just add another charger for the dedicated banks or you could replace the existing with something that will do everything (but more $$$$)
