starts then dies
- mchild3028
- Vessel Info: 1987 32 carver
starts then dies
Hello, 1987 32 carver no start both Eng Starts the dies, I have power at positive side of coil when cranking, no power at ballast resistor but i have power coming out of ignition switch, is there a shut off switch? where can i find a wiring diagram? Thanks
- mchild3028
- Been thanked: 1312 times
Re: starts then dies
To be clear, both engines have exactly the same problem ? A little more info could help the guys.......did this just start like this or has it been on and off ?
As far as a diagram....try a search for mercruiser inboard engine wiring etc, etc.
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
Most of these issues are fuel related. Is it old or bad fuel? Have you changed filters? Cleaned up your flame arrestors? Anyway, try this PDF link
https://carveryachts.blob.core.windows. ... ver_87.pdf
er
erCooler By The Lake
