Grounding, Not Good
- Has thanked: 455 times
- Been thanked: 1671 times
Re: Grounding, Not Good
You should be able to get the shafts manufactured locally right away at a prop shop if the supplier doesn't have them.
How long for the props?
Fingers crossed everything is available sooner than later.
- Been thanked: 1043 times
Midnightsun wrote:Source of the post
<snip>
Rudders seem ok but the port one seems to have a small angle to it if you look carefully or it is just an illusion.
<snip>
As a quick check on the rudders, it would seem like you could lay a GoPro or similar video camera under them, pointed up to the hull, then turn the wheel hard port to hard starboard and you'd see if there was any bend in the shaft.
- denpooch
- Has thanked: 85 times
- Been thanked: 86 times
I do know that my Garmin chartplotter posts a 'disclaimer' when it boots up. Perhaps the lesson we can all learn is to cross-reference our electronic routes with the good old time paper charts, especially when navigating in unfamiliar waters. Good luck.
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 467 times
- pepmyster
8.1 Volvo Penta
- Has thanked: 474 times
- Been thanked: 201 times
- Cooler
- Has thanked: 68 times
- Been thanked: 390 times
- Has thanked: 324 times
- Been thanked: 595 times
- Has thanked: 268 times
- Been thanked: 1153 times
Insurance has been informed and the estimator has already inspected. The mechanic is well on his way removing the shafts and struts which should be complete in a couple of days. Found out almost anyone can fabricate new running gear in about a week so it looks like maybe 3 weeks and I should be back in if all goes well that is. Surprizingly enough newly machined shafts deliver in 4 day to a week.
- Has thanked: 579 times
- Been thanked: 1210 times
Users browsing this forum: No registered users and 121 guests
