Port Engine runs hot on plane
paboater76
Vessel Info: 84 3207 Aft Cabin
Has thanked: 14 times
Been thanked: 5 times
Re: Port Engine runs hot on plane
Post by paboater76 »
vineyardgray wrote:QR_BBPOST Excuse my ignorance - what's a CAM plate? :worthy:
The cam plate is inside the sherwood E35 raw water pump, it is responsible for compressing the impeller fins to create suction/pressure. It is a wear item and should be checked for minimum thickness.
Been thanked: 1114 times
Normally it's just called a cam. You can see it in the picture below, highlighted with the red arrow. It's the crescent-shaped piece at the top, that's used to compress the rubber impeller vanes. It's held in place by one screw coming in from the top.
The back plate, sitting next to the pump in this picture, can also be a wear item, as it can get grooves in it from many hours of use.
Somewhere I have a picture of a worn cam next to a new cam, but I can't seem to find that right now.
